Kawasaki Quad's & ATV's Quad (Leisure) & ATV (Working) talk within here.
help antifreeze leak
Old Aug 1, 2006 | 01:24 AM
dedbrok's Avatar
Default help antifreeze leak
Not mine, but a friend of mine has a prairie 700 and last night it blew a hole in what appears to be some sort of inline valve for antifreeze. I'm not that familiar with them so what is that? is it needed? where can he get one?
thanks
Old Aug 1, 2006 | 03:04 AM
dedbrok's Avatar
Default RE: help antifreeze leak
you cant miss it really , it's on the right side(as you are sitting) right behind the section of tubing that goes down to the case. at first glimpse it looks like an inline filter, but once we got it off we could see that the fat end had a white plunger type valve.
Old Aug 1, 2006 | 06:24 AM
BigRig18Wheeler's Avatar
I am not real sure which piece you are talking about. But I have never owned a newer model 700 either. They have come along way since my old 400ex..lol..... Maybe a heat control valve?
Try this link and see if you can indentify which part it is....
http://houseofmotorcycles.bikebandit...A2%29.asp#stay
Welcome to the forums....
Old Aug 1, 2006 | 07:02 AM
dedbrok's Avatar
thanks for the link, i emailed them hopefully they will get back with me. it looks like the part would be 16160B but the piece going in it is listed as a fuel filter so I'll know for sure tomorow.
thanks
Old Aug 1, 2006 | 07:33 AM
No problem, man..... GL to ya..
Old Aug 11, 2006 | 03:15 AM
Blackkawi400's Avatar
I willing to bet you are speaking of the thermostat. It controls coolant flow according to the temperature of the engine.
When the engine is first started, it restricts flow until the motor heats up, once at operating temperature, it allows the flow of coolant to keep the temperature of the engine stable.
You should definetly be able to pick one of those up at the stealership.
BlueDevil636
Jan 2, 2008 03:16 AM
LordVngr
Nov 17, 2006 09:35 PM
PALYDIN11
Oct 25, 2006 08:11 AM
Cold Iron
Jul 24, 2006 09:47 PM
ZX12Rider
Feb 3, 2005 03:54 PM
