no first gear
Old Aug 13, 2007 | 11:52 PM
muddy's Avatar
Default no first gear
the mule was partially under water. engine runs fine, just no first gear, is there a shift solinoid that could have been shorted, everything else seems to be functioning properly. gas motor, 4 wheel drive 52 hours on it. please help
Old Aug 21, 2007 | 02:52 AM
mmi86's Avatar
Default RE: no first gear
The Multiuse Utiltylight equipment (mule) uses a CV Transmission there are no gears there for no main gears and counter gears,on the mule only a drive, driven pulley and a Gilmer style belt can be found
Old Sep 2, 2007 | 10:31 AM
bymannan's Avatar
Check the CV plastic cover at the left side of the engine, if water penetrate to the CV the belt will slip. Also check the tube that is connected to the CV, it should be connected and sealed between the CV cover and the rollover tube.
rajdeep
Aug 21, 2008 12:31 PM
kx slaughter king
Jul 7, 2008 02:29 PM
vermont6r
Apr 21, 2008 05:41 AM
russells8867
800, 800 Classic & 800 Drifter
Jan 28, 2008 03:35 PM
Chris90Ex5oo
Ninja 500R
Apr 10, 2006 08:10 PM
