Mule 3010 Trans 4x4 Diesel oil leak
Old Sep 1, 2017 | 02:45 AM
John A's Avatar
Question Mule 3010 Trans 4x4 Diesel oil leak
We have a 2010 model 3010 diesel that we use in the middle of the jungle in Papua New Guinea (flew it in here by chopper in pieces and rebuilt it...only one trail we use it on, no access to town from this place). Been using it full-time since 2013.
It just developed a serious engine oil leak that we are having a hard time locating. Leaks more sitting still than when it is running.
We have limited tools and even more limited knowledge. We are literally bush mechanics. Any ideas where to find the leak? Our worry is that it might be at the drive output/crankshaft. Thanks!
Old Jan 1, 2018 | 11:55 PM
cekramer's Avatar
Hi John,<br /><br />I too have had this problem, have looked with a borescope all around motor, changed drain plug, double checked around oil filter and oil pressure sensor....no luck. Drips from bottom of skid plate only when recently run...half a dozen drips then stops. Like a reservoir gets filled , empties over time, then stops. Just about ready to pull the engine.<br /><br /><br />Hope we can find some one who has addressed and solved this problem.<br /><br />Chuck<br />Port Angeles, Wa.
Old Jan 25, 2018 | 03:42 PM
Rob9876's Avatar
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
Kawasaki ATV and Mule - Kawasaki Motorcycle Forums
Uyless1
Jun 9, 2019 04:25 PM
buschdog123
Aug 22, 2017 04:00 AM
chromedome
Feb 23, 2017 01:38 AM
Shadygrady
Oct 9, 2015 12:48 AM
