jumper wire plugged into accessory bundle under dash
Old Aug 7, 2024 | 09:31 PM
whatthukawaski's Avatar
Default jumper wire plugged into accessory bundle under dash
I need some help. I have a 2021 Mule 4010 trans 4x4 FE (KAF622) While installing the hydraulic bed lift in the instruction manual 9999418747 page 5 step 11 says i need to plug the relay switch barrel wire into a brown wire with a blue stripe located in an accessory bundle under the dash. Well, under my dash i have 3 accessory bundles, two up close to my right knee ( while sitting) tied to a horizontal bar and one further back tied to a vertical bar (near the steering shaft) which also shares the tie with a main wiring harness. The only brown wire with a blue stripe (actually a blue band) is in the furthest bundle tied to the horizontal bar which has this strange jumper that feeds into a light green barrel wire in the same bundle. The jumper is also color coded with inline fuses and rests in a black plastic sleeve with electrical tape sealing it off and a white label with some Chinese/Japanese symbol on it as well as the letters ASTI (as memory serves). I have called a few dealers and no one seems to know what this used for. I have tried unplugging it and everything seems to work fine. One tech seemed to think it may have been left over from the factory when they build/test them. Any one else run into this mystery jumper wire? Thoughts? BTW the brown with with the blue band operates from the on/off key like the brown and white barrel wires in the other bundles. See pictures attached.
Dojoburns
Ninja ZX-1100R
May 27, 2024 09:51 PM
ramsey.mangus
Aug 8, 2018 04:36 AM
a1parrothead
Jul 16, 2010 07:56 AM
arizonazx11
Mar 3, 2009 07:47 PM
2k1w=no$
Jul 3, 2008 12:59 AM
