98 Mule 2510 prop shaft rubbing
Old Aug 29, 2023 | 04:42 AM
Keith1517's Avatar
Default 98 Mule 2510 prop shaft rubbing
Hello all. First time posting. I recently aquired a 98 Mule 2510. I have been going through it getting the mechanicals cleaned up. I noticed the 4wd prop shaft is rubbing the plastic cover on the carb side of the motor. It appears that the motor is slightly crooked in the chassis. I have loosened the 4 motor mount bolts on the bottom but could not get it to move. Any ideas? I dont need much clearance there, just enough to keep the shaft from rubbing. I don't think that anything is bent, although I haven't put a tape on anything. It might be worth adding that there is a 2 inch lift kit in the front but the back is not lifted. Also, it is on 12 inch wheels vs the stock 10s. I cant see how this would change the prop shaft geometry being that it runs to a universal coupling block, but I could be missing something. Thanks
mike0317777@gmail.com
May 15, 2023 10:13 PM
Ian Sinclair
Jun 26, 2022 03:19 AM
idgarza
Mar 13, 2022 07:58 PM
SSMULE
Oct 2, 2019 02:51 PM
dalbright
Jun 12, 2007 01:03 AM
