98 Mule 2510 prop shaft rubbing
Hello all. First time posting. I recently aquired a 98 Mule 2510. I have been going through it getting the mechanicals cleaned up. I noticed the 4wd prop shaft is rubbing the plastic cover on the carb side of the motor. It appears that the motor is slightly crooked in the chassis. I have loosened the 4 motor mount bolts on the bottom but could not get it to move. Any ideas? I dont need much clearance there, just enough to keep the shaft from rubbing. I don't think that anything is bent, although I haven't put a tape on anything. It might be worth adding that there is a 2 inch lift kit in the front but the back is not lifted. Also, it is on 12 inch wheels vs the stock 10s. I cant see how this would change the prop shaft geometry being that it runs to a universal coupling block, but I could be missing something. Thanks
