03 3010 4x4 mule transmission problems
Old Mar 25, 2019 | 02:17 PM
goldstar's Avatar
Default 03 3010 4x4 mule transmission problems
I have an 03 3010 mule it will not go forward in high gear. It will move forward reluctantly in low gear. It will reluctantly back up in reverse in low or high gear. Thank you if someone could help.
Old Jun 9, 2019 | 05:16 PM
CrashWrench4010's Avatar
Hi,
Time To Check The " Main Drive Belt ' And Both " Clutches " .Check Your Service Manual , the " Main Belt " Has To Be Measured For Belt Stretch And Width . If Either Clutch ( Engine " Drive " Clutch or Tranny " Driven " Clutch )
If There is Dirt , Oil , Excess Belt Dust , Any of Above ,,, And No Power Will Get To the tranny . Also check the Shift Cable(s) For Proper Adjustment .
treeninja
Aug 15, 2019 01:59 PM
Mcrib
Jan 25, 2018 03:39 PM
Rhoda Mule
Dec 27, 2016 03:05 AM
rras1
Oct 29, 2012 08:40 PM
Older Not Wiser
Aug 4, 2009 10:27 PM
