03 3010 4x4 mule transmission problems
I have an 03 3010 mule it will not go forward in high gear. It will move forward reluctantly in low gear. It will reluctantly back up in reverse in low or high gear. Thank you if someone could help.
Hi,
Time To Check The " Main Drive Belt ' And Both " Clutches " .Check Your Service Manual , the " Main Belt " Has To Be Measured For Belt Stretch And Width . If Either Clutch ( Engine " Drive " Clutch or Tranny " Driven " Clutch ) If There is Dirt , Oil , Excess Belt Dust , Any of Above ,,, And No Power Will Get To the tranny . Also check the Shift Cable(s) For Proper Adjustment . |
