Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
removing impeller on 95 900 zxi..
Old Sep 3, 2006 | 12:17 AM
ekoster's Avatar
Default removing impeller on 95 900 zxi..
have the cone housing off, removed the four bolts from the face of the housing in front of the impeller and removed the 2 bolts from the ride plate that look like they go into the same housing. can't get housing off. Am I missing something?
Old Sep 3, 2006 | 01:35 AM
BigRig18Wheeler's Avatar
Default RE: removing impeller on 95 900 zxi..
Welcome to the forums man.. I am not sure on your ski..... If someone does not get the answer for ya, I'll see if I can find out.
Enjoy your stay!!
Old Sep 3, 2006 | 02:11 AM
winterpop's Avatar
These come off as a single unit. Take off all the bolts that go threw the jet pump casing into the jet ski. I take off the water grate first working back to the rear of the jetski. There may be some rubber holding it in place, so knife that away. With all the bolts off, the only thing holding it to the ski is the shaft, so slip it rear ward off the shaft.
Now if you have the cone off, you will see a ****. If you turn the **** the impeller turns. I put that **** into a vice, standing up the shaft end. Now I insert impeller tool, (Tool is about $11.00) put a big wrench on impeller tool and the impeller will come off.
Old Sep 3, 2006 | 02:55 AM
ekoster's Avatar
ORIGINAL: winterpop
Are you talking about the four bolts that are inside the engine comparment that attach the plate on the inside of where the jet pump casing would be? Is it necessary to take the intake grate off?
Old Sep 22, 2006 | 06:25 PM
meangreenman's Avatar
No bolts to remove from INSIDE the engine compartment. Don't even remove the seat!
1. Remove the ride plate.
2. Remove the intake grate.
3. Remove/detach steering cable, hoses, etc. from the jet pump.
4. Remove the 4 bolts (using 14-mm socket) that holds the jet pump assy to the back of the ski - as you look from the back, you will see the 4 bolt heads.
Rugbygreyhound
Jun 19, 2023 04:51 AM
haz
Jan 21, 2015 02:12 AM
Coconcade
Oct 8, 2013 04:18 PM
Jfawcett
Jul 7, 2011 10:26 PM
purp95gt
Aug 2, 2008 02:47 PM
