Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
overheating
Old Sep 23, 2006 | 06:11 PM
silverado's Avatar
Default overheating
i have a 96 kawasaki jet ksi ss and it runs fine when its hooked up to the hose but it doesnt get any water when is in the water ....can anyone help
Old Sep 25, 2006 | 05:59 AM
meangreenman's Avatar
Default RE: overheating
It seems that your intake cooling hose is clogged up. There is at least couple of ways to go about this. You can either disconnect the inlet cooling hose between the jet pump nozzle and transom bulkhead fitting, or the inlet hose iniside the hull between the transom and the engine/exhaust. You will either have to blow it out using high pressure air/water or clean out with a wire coat hanger. If neither works, you will have to remove each cooling inlet hose/fitting and check it out.
jnut
Jun 5, 2007 11:38 PM
DragonZ
Dec 19, 2006 09:11 AM
DragonZ
Ninja ZX-1100R
Nov 26, 2006 09:50 AM
tbav8or
Jul 29, 2006 04:53 PM
Gerg
Jun 26, 2005 03:41 AM
