Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
new owner
Old Jun 17, 2006 | 11:04 PM
jeepguy's Avatar
Default new owner
i just bought a kawasaki jet ski and i was looking for some tips (do's don'ts) i have ridden before but never owned so i know the basics, i was also told that it is an 89 or 90 are there any ways to tell what year for sure? all i know is that it's a 650 ts 2-seater
Old Aug 2, 2006 | 11:17 PM
oneeye212000's Avatar
Default RE: new owner
you vin number will tell you what year, i think it will be the last two digits.
Old Sep 1, 2006 | 07:18 AM
kawman's Avatar
Last 2 numbers is the year!! Remember no Brakes!!!!!!!!!!!!!!!
Old Sep 20, 2006 | 11:27 PM
meangreenman's Avatar
The black plastic HIN tag's last two digit should show either 89 or 90 if you think it is either 1989 or 1990 model. They are mechanically the same - just different C&G. The only problem that I am aware of on this model is to make sure there is no fuel leak inside the engine compartment. If you smell or see gas there, check it out carefully. You don't want to experience unnecessary bang when you press the green start button.
Old Sep 30, 2006 | 07:07 PM
clht's Avatar
I'm new owner of a used 96' model 900 xzi. I've been told that they need to be flushed out after every use. To clean the trash out of the ski from the lake. My question is where do you do this and how????
Old Oct 4, 2006 | 12:45 AM
Flushing...
Yes, it is a good idea to flush out the engine even if you were just riding in a fresh water lake, because debris, trash & sand could be remained inside the cooling path. Where to hook up? On your 900, look at the top of the exhaust manifold. There should be a L shaped brass fitting with black rubber cap. That's where you hook up your garden hose end - you will need an adapter though. Make sure you start the engine first, then turn on the hose water about only 1/2 turn to prevent flooding inside the engine.
optimuzs
Sep 14, 2012 04:19 PM
barny
Jul 31, 2010 03:37 AM
buff36
May 27, 2009 03:36 AM
mwerneke
Jun 20, 2008 04:19 AM
Bonafide
Apr 16, 2006 08:21 PM
