Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
How to replace rivets holding rear bumper pad on 2008 STX-15F
Old Apr 29, 2013 | 04:46 PM
Western NC's Avatar
Default How to replace rivets holding rear bumper pad on 2008 STX-15F
I recently purchased two Kawasaki STX-15F jet skis with very low hours but minor cosmetic issues. The rear corner bumper pad has sustained a hard enough hit to snap off two of the rivets holding it in place. I've already purchased replacement rivets & cap blocks, however, I'm not certain how to get the broken rivets out. The end of them appears to snap into something permanently attached to the underside/inside of the bumper. There doesn't seem to be anything remaining on the outside end of the rivet to grab onto to pull the old rivet out.
Has anyone run across this problem before and if so what's the solution?
I've attached a parts blowup for clarification.
Attached Thumbnails How to replace rivets holding rear bumper pad on 2008 STX-15F-2008-stx-15f.jpg
Old Apr 29, 2013 | 07:37 PM
Hmmmmm Unless you can get to the underside of the rivet and pull it through the rest of the way, you might have to drill next to it and put new ones in. Usually drilling with a larger then the head drill bit will remove them, in your case that's not an option. Oh and welcome to the forums.
duke
Jul 29, 2009 04:17 AM
gs350on22s
Jul 28, 2009 01:10 AM
sickawi06
Sep 9, 2007 06:22 PM
KawiZX6R2006
Jun 28, 2007 05:52 AM
Nutter78
Oct 4, 2006 06:57 AM
