Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
750 SS won't start
Old Sep 9, 2006 | 01:04 AM
newbie mech's Avatar
Default 750 SS won't start
My 750 won't turn over. It continues to roll and will run only as long as I continue to spray starter fluid into the carburetor. Any suggestions on where the problem can be. What's between the fuel tank and the carburetor that could cause a problem? What can I do to test for something being clogged and what can I do to unclog all the way through?
Old Sep 20, 2006 | 11:02 PM
meangreenman's Avatar
Default RE: 750 SS won't start
If your engine only runs on starting fluid, either you have a fuel pump or choke problem. More likely the fuel pump. Disconnect the suction tube from the fuel pump (attached on the side of the carb) and put your fand at the fitting while you are cranking. If you don't feel any suction, your fule pump needs rebuilding (diaphragm) or replacement.
mdr130
Jul 17, 2009 11:38 AM
wakeboarder82420
Jun 29, 2009 03:31 PM
cajuncheech22
Jun 14, 2008 11:51 AM
