Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
2000 Kawasaki 1100 STX Fuel sender and Storage Case questions
Old May 22, 2026 | 11:41 PM
ClarkFork's Avatar
Default 2000 Kawasaki 1100 STX Fuel sender and Storage Case questions
Jet Ski: 2000 Kawasaki 1100 STX
I am seeking a bit of guidance before I start taking everything apart. Many thanks in advance.
Q1: With a full tank, the fuel level light comes on and the fuel gauge shows no fuel-level information. Safe to assume the Fuel-level sender needs replacement?
Q2a: I found a couple of good You Tube videos to replace the fuel-level sender, but those jetskis are 1999 models. Mine is a 2000 and the "bow locker" riveted to the hull. It appears the only way to access the fuel-level sender is to remove the Seat, "front storage case" and Cross member. Anyone done this?
Q2b: When removing the "front storage case" is there enough wire for the orange key and switch to keep it out of the way?
Thank you in advance
rsons1965
May 24, 2024 03:23 PM
robin
May 15, 2022 09:33 PM
twistable_deer
Oct 28, 2021 06:24 PM
Ahm2kewl
Oct 2, 2020 05:02 AM
loser77
Jul 28, 2010 12:11 AM
