Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
1995 STS 750 Jet Ski
Old 08-28-2005, 03:26 PM
jprickett's Avatar
Default 1995 STS 750 Jet Ski
My Jet Ski starts great, has good power. After 15-20 minutes it starts dying. It is just like it shuts off. I can restart IF I use the choke. It will die again after running a short while. I can keep it going only if I hold the choke at 3/4 closed. I have checked the carbs, plugs, fuel supply, all are OK. Help!
I believe my problem may be associated with the cooling water temp sensor. How hot can the cooling water get before the sensor starts shutting the engine down? What should the maximum water temperature be at the bypass outlet on the right side???
Please help, I am stumped!
Old 04-07-2006, 02:03 AM
ck's Avatar
ck
ck is offline
Default RE: 1995 STS 750 Jet Ski
I was wondering if you know if I should change the oil on the crank case.
Sae 30 ?
C
Old 10-02-2007, 10:14 PM
BARLOWSRUN's Avatar
NO! THERE IS NO CRANKCASE OIL. IF YOUR REFERRING TO THE FRONT PLUG ON YOUR ENGINE, IT DOESNT GET OIL.....
Old 10-04-2007, 01:44 AM
KLX450R's Avatar
You should remove the fuel pick up from your fuel tank and make sure that the screens are clean and also the aluminium section near the top is known to corrode and not allow the tank to take in fresh air to allow fuel to flow. Try tracing the vent line(usually to the handlebar cover is where it leads) and look into the end to make sure dirt dobber wasp hasn't stopped it up.
If this fails, try replacing the fuel pump diaphragm. They can be purchased in a kit aftermarket for half the price of the oem pump housing.
ready_2_retire@yahoo.com
08-11-2015 01:48 AM
joeski49
10-08-2013 04:05 PM
danriley50
05-13-2007 05:35 PM
mason_rigby
06-19-2006 09:28 AM
drwieg
05-29-2006 09:45 AM
Quick Reply: 1995 STS 750 Jet Ski
