ZX9R indicator (turnsignal) fault
Old 05-08-2010, 04:20 PM
relax_in_de_sun's Avatar
Default ZX9R indicator (turnsignal) fault
I have a ZX9R (99) and have just had LED indicators fitted. I changed the relay to get the correct flash rate and everything was good. Then on my way home from work the indicators stopped working and I found that the fuse had blown. I changed the fuse and they work ok again appart from when I activate my immobalisor. Both sides used to flash now only the left flashes however the indicators still work correctly when I'm riding. I have swapped the relay with anther ZX9R but this has not solved the problem. The immbalisor has always been on the bike as far as I am aware of. Any suggestions please
Old 05-08-2010, 07:19 PM
Prom's Avatar
hmmm, not sure on your flashers, but fuses typically dont blow unless there is a problem, if you can figure out what caused the fuse to go maybe you can find the issue.
Welcome to KF!
Old 05-09-2010, 01:12 AM
Welcome to KF
You have fried a fuse and a relay after your led install. Sounds like your setup is maxing out the contacts of the relay and of the fuse. Double check your amp draw. good luck on the troubleshoot
pas71985
08-25-2011 02:53 AM
PhillipZX6R
04-01-2008 05:46 PM
maurice
KLR250
05-06-2006 09:37 AM
shyde555
04-14-2006 05:06 PM
gotrice
09-09-2005 08:25 AM
Quick Reply: ZX9R indicator (turnsignal) fault
