zx6r high mph problem
Old Oct 12, 2008 | 02:01 AM
SIANAGROM68's Avatar
Default zx6r high mph problem
i have a zx6r 98 when im in first and second gear and full throttle its fine as soon as i get in third or fourth about 120 mph it bogs right down like to much fuel but i dont under stand why does anyone know of any problems like this
Old Oct 12, 2008 | 05:35 AM
whitehendrix's Avatar
Vacuum leak. check the vac lines running to the airbox.. bet ones off.. usually in the Kleen air system or float pressure air line.
welcome to KF!
Old Oct 12, 2008 | 05:54 AM
and now for an explaination as to why i say this. cuz i'm bored
at W.O.T., intake velocities are approximately 120MPH, therefore, at such speed, the ram air starts to create positive air pressure on the carbs and airbox. a vac line leak will pressurize the float bowls unevenly in the carbs and result in a lean condition. bet ya dollars to dounuts it backfires like a MF'er when you're at speed, and it stumbles a bit at moderate-speed heavy acceleration? (around 60-90mph, 5th and 6th gear roll-ons..)
punkenduro09
Dec 8, 2014 08:28 AM
sysroot
Oct 25, 2012 06:15 AM
Nickawasaki
May 20, 2011 12:55 AM
MikeA12
Jan 24, 2007 05:11 PM
Sublime
Aug 20, 2006 04:08 AM
