Zx6r f2 vacume fuel and air valves
Hi all
I'm new to the forum and would appreciate your help with an issue.
I bought a zx6r f2 which had been streetfightered. The previous owner seems to have removed the air valve and fuel vacume valve that sit in front of the carbs.
I have these valves and want to reinstall the system to its original form.
My question is, where do the hoses go on the fuel valve, I know the top hose comes from the air box but there is a smaller hose on a t piece, does this go to the carb vacumes.
Similarly the air valve below, I know two hoses go to the crank case and one to the air box, but again does the smaller hose with t piece go to the carbs.
I hope this makes sense and look forward to any info you can give.
Thanks all
Thanks all
