Airbox Mod Question - KCA Air Suction System
When your doing the Airbox mod, do you also disconnect and plug up the KCA Air Suction System? If so do you plug up both the airbox port and the Air Suction Valve? or do you put a breather filter on the Air Suction Valve and just plug up the air box port?
Any insight would be great, thanks,
Dave
Dave
ORIGINAL: DirtSurfer
Dave
Dave
ORIGINAL: tremor38
Has anyone come-up with a better solution than Help brand plugs and caps?
Sounds like it might hold-up better. I was actually thinking of the same thing.
I also remember an old mechanic's trick of pushing an appropriate sized steel ball bearing into vacuum hose. The trick was to find a ball bearing that fit tightly into the hose and would also be too large to get sucked into the nipple. This would, of course, require the hoses to be left in place, which is not desirable for most of us here. I was just looking for an interim solution until something better than the Help plugs can be found.
ORIGINAL: EMS_0525
thats what im wondering... those things crack... thats y that system is still on my bike... im thinking of just cutting the hoses off short and getting a bolt to fit in the end of the hose and use a hose clamp to hold it in there and use the bolt as a plug... that wont crack or dry rot or whatever.... any thaughts on this?
ORIGINAL: tremor38
I cut the reed valve inlet hose off to 2" and capped that with a hose plug. 2" seems to be enough to keep the heat of the head from melting the plug.
Good idea. I'll probably go that route.
ORIGINAL: bmwhd
