zx6r clutch question
Old Mar 19, 2007 | 02:44 AM
ffunnyman's Avatar
Default zx6r clutch question
I think that my clutch might not be fully disengaging. When you put it into first from nutural it jumps a little bit(a little bit of a clunk). Also pushing it in first with the clutch pulled in all the way I can feel the energy hit the engine and they you have to turn the engine with the pushing. Does this sound odd. I tried to check the cable but i'm somewhat confused. It seems to start pulling the arm right away(no play?) and also will go all the way down until the handle is pushing against the grip.
Is this normal?
I was also thininking it might just be from not going anyway all winter, since I don't think it did it before, but im not sure.
The bike is almost ready for the road now.
thanks
jason
Old Mar 19, 2007 | 03:12 AM
markmeinteil's Avatar
Default RE: zx6r clutch question
A slight jump when you first put it in gear with the engine still cold is nothing to worry about. If it jumps when the engine has fully warmed up, you might have some issues. You should be able to make cable slack adjustments at your lever's adjusting sleeve by turning it clockwise or counter-clockwise.
jcbowling1985
Ninja 250R
Oct 19, 2012 05:35 PM
RayCour
Jul 21, 2010 10:35 PM
deej
Oct 2, 2008 09:58 PM
JERSEY
Apr 23, 2006 08:30 AM
