Where to buy replacement engines
Old Apr 15, 2014 | 07:41 PM
2slw4u's Avatar
Default Where to buy replacement engines
Hello everyone Im new on here but i have a 2004 KX250F and i recently blew the engine on it. I am looking where to buy an replacement engine rather than going through the dealer. If you guys would please let me know where to get one! Thanks everyone!
Old Apr 15, 2014 | 11:13 PM
You can see if Kaw sells them. But there is no doubt in my mind you can tear down and replace the broken parts in your bike unless you put the rod through the cases.
A whole engine includes the gear box - expensive.
Old Apr 16, 2014 | 01:20 AM
Welcome to KF
+1 to above. give us more detail
Old Apr 16, 2014 | 05:53 AM
2slw4u's Avatar
thanks for the welcome! well when i was riding at the track about a few months ago I did this 40' tabletop and i think I may have over reved in the air and when I landed the bike just shut off. The kick starter wont kick its basically stuck in the up position. I am thinking I may have mangled the valves possibly. I haven't tore into it yet due to me finishing my rx7 as one of my other projects but the weather has been so nice out here in colorado want to start riding again!
Old Apr 16, 2014 | 05:54 AM
2slw4u's Avatar
and forgot to mention that say i put it into gear like 1st and rock it back and forth then try to kick it it will kick but then when I try to kick again it wont budge until I rock it back and forth again. So I am quite puzzled
Old Apr 16, 2014 | 02:28 PM
Tearing it apart is free....oh and welcome to the forums.
Old Apr 16, 2014 | 03:53 PM
2slw4u's Avatar
haha right! ya Im going to tear into it this weekend. I have finals coming up and lots of HW this week to be ready for them. Ill post some pictures of the progress
Old Apr 16, 2014 | 09:26 PM
Still it will be cheaper to buy parts and rebuild versus trying to buy a new engine. The "new engine" thing is a bit of a throw back to the car thing. A crate engine, a long block, or short block are not unusual, but they don't have a clutch and transmission with them.
Now maybe not if you buy a used bike with an engine, possibly a wrecked frame, but good engine.
I hope you find it's something simple. Remember this is a small engine. Everything should come apart easily. If not odds are there is a special tool puller required to get the part off properly, like popping off the ignition rotor. If your engine cases don't split easily look again for a screw/bolt you forgot to remove. They're pretty skillful at sticking fasteners in the weirdest places. I had a shift return spring break on my KLX650. Four of five fasteners came out unobstructed. The fifth was hidden behind the inner stator cover. I had to pull the outer cover/windings, then have the mechanic at the shop where I used to work pull the stator rotor with a special puller tool, a bigass 1/2 drive impact, and a bigass hammer to get the inner cover off... just to get to one allen bolt! The sad part - they could have rearranged the fastener locations to make it come off without any other disassembly... stupidity in engineering.
Old Apr 17, 2014 | 03:05 AM
2slw4u's Avatar
well I did dig into the bike today, and first off im retarded I didnt catch me writing 04 its a 06 kx250f. sorry about that haha. But i did pull the head off and found that the intake came retainer snaped and caused a valve to break as well. I pulled the cylinder out as well and it still has the factory cross hatching and even the piston still looks great! The head is ruined it ground down one of the oil jackets on where the cam sits. SO I am in need of a head if anyone has one for cheap so I can get this thing running soon. I drained the oil and had no metal flakes in the engine. Ill probably pull the clutch covers and oil housing cover to make sure no bits dropped to the bottom end as well.
Attached Thumbnails Where to buy replacement engines-kx3.jpg   Where to buy replacement engines-kx2.jpg   Where to buy replacement engines-kx1.jpg
mthomas
Nov 9, 2010 01:12 PM
modifiedZX10r
Oct 14, 2007 02:12 AM
Will Shoe
Sep 7, 2007 04:52 PM
mycat8urskidoo
Ninja 500R
Apr 4, 2007 09:31 AM
poodlenuts
Jan 15, 2007 06:46 PM
