What stops the center stand when you add a new exhaust?
Old Mar 22, 2008 | 11:52 PM
blacktalon606's Avatar
Default What stops the center stand when you add a new exhaust?
I put a single pipe D&D exhaust system on my 85 zx600 A1, that exits to the right side of the bike. It appears that the center stand had previously rested against the left exhaust pipe when it had the factory dual system. I wouldn't worry about it, but the center stand is now resting against the chain. Is there something I can buy to bolt on or am I going to have to make something?
Old Mar 23, 2008 | 06:50 AM
BigRig18Wheeler's Avatar
Default RE: What stops the center stand when you add a new exhaust?
Do you mean the side kick stand or the center stand? If it is the center stand, why don't you just remove it?
Old Mar 23, 2008 | 09:18 AM
There should be a stop for the center stand. Should not rest on the chain or on the muffler.
Old Mar 23, 2008 | 01:58 PM
I mean the center stand. I had considered just removing it, but I use it often.
Yes, I realize It shouldn't rest against the chain. Lol. 10 miles of riding the chain would either break or it would cut through the center stand. The original center stand stop was a square welded to the left exhaust pipe and there is a rubber bushing on the center stand called the center stand dampener.
Old Mar 24, 2008 | 04:44 AM
Yep...I don't know of any kind of bolt on fix, unfortunately..... I'd say make summin, or remove center stand. Shouldn't be to hard to fab summin up to work...
Old Mar 24, 2008 | 11:46 PM
Yeah, making up a bracket as mentioned, weld it to the exhaust and place the $2.97 92075 Damper Rubb main stad in place.
kyrral
Jan 31, 2011 12:33 AM
yorgomiami
Ninja ZX-1100R
23
Jul 18, 2009 01:56 AM
bkyee
Ninja 500R
Nov 26, 2006 03:25 AM
bkyee
Ninja 500R
Sep 11, 2006 12:31 PM
payne.280
Ninja 250R
May 16, 2006 04:36 PM
