vibration
Old Aug 16, 2006 | 02:34 AM
Live2Ride's Avatar
Default vibration
Hi all I have a 2006 636, with 2500 miles on it . Been getting a vibration noise ,almost a buzzing noise traveling through handle bars. Any ideas??????????? I also notice the vibration shifting at higher RPM's
Old Aug 16, 2006 | 02:38 AM
Bluebeast's Avatar
Default RE: vibration
I would check the bolt on the steering head. It might be loose causing you to get the vib's in your bars. Or you might have a wheel weight that may have come off or it could always be the road your riding on too. Hope this helps you out a little.
Old Aug 16, 2006 | 02:44 AM
Live2Ride's Avatar
what about the engine mounts?I had the bike lowered about a month ago at the dealer. I installed frame sliders. Do you think they would possibly be a cause to the noise?
Old Aug 16, 2006 | 04:19 AM
Bluebeast's Avatar
It's possible that it might be making you bike vib. I would just make sure everything it tight and take it out for a ride. Let us know here if it help.
Old Aug 16, 2006 | 07:49 AM
BigRig18Wheeler's Avatar
I have to agree with Blue beast....Check every bolt and nut. Especailly since someone has messed with the bike. Double check the air pressure...If everything seems tight and up to par, that's what that warranty is for.... GL man..
Old Aug 16, 2006 | 08:20 AM
evil636's Avatar
Knee Dragging Pimp
i bet the pink slip to your bike its the clutch lever humm. ill be back with a link.
Old Aug 16, 2006 | 08:24 AM
evil636's Avatar
Knee Dragging Pimp
Old Aug 17, 2006 | 03:52 AM
racedoll's Avatar
I'm betting a tire is out of balance or the fork settings don't match.
Old Aug 17, 2006 | 04:26 AM
evil636's Avatar
Knee Dragging Pimp
ORIGINAL: racedoll
50 bucks says its the clutch lever
Old Aug 17, 2006 | 05:27 AM
racedoll's Avatar
ORIGINAL: evil636
The buzzing noise, very high possibility. I didn't read that part the first time.
