Turn Signal wont flash
I recently installed aftermarket turn signals on my bike. The light wouldnt flash on the right side. I then order aftermarket led turn signals because some water got into the other flashers. Now the light wont flash on the left side but flashes on the right. Any ideas what is happening and how to fix this?
O/C wire or connection. Check the bulbs, and make sure they're the same wattage as the origuinals or the loadon the flasher unit won't be correct.
Make sure your LED signals have the correct value resistor fitted.
Rob
Rob
Matasickle
May 27, 2011 01:31 PM
