Turn Signal wont flash
Old Sep 10, 2008 | 12:57 PM
87kawi500's Avatar
Default Turn Signal wont flash
I recently installed aftermarket turn signals on my bike. The light wouldnt flash on the right side. I then order aftermarket led turn signals because some water got into the other flashers. Now the light wont flash on the left side but flashes on the right. Any ideas what is happening and how to fix this?
Old Sep 11, 2008 | 12:50 AM
RonInFla's Avatar
Go back thru the wiring. sounds like your missing the ground on it.
Old Sep 11, 2008 | 04:54 AM
are you watering your signals? Sounds like either a bad install or a bad design.
Old Sep 11, 2008 | 11:19 AM
williamr's Avatar
O/C wire or connection. Check the bulbs, and make sure they're the same wattage as the origuinals or the loadon the flasher unit won't be correct.
Make sure your LED signals have the correct value resistor fitted.
Rob
Matasickle
May 27, 2011 01:31 PM
dusan498
Oct 7, 2010 01:50 PM
cenzo89
Dec 18, 2008 04:45 PM
kenny_426
Aug 13, 2008 07:01 PM
Mr. Toad
Mar 30, 2006 05:57 AM
