time for the valve adjustment
Old Dec 24, 2006 | 07:37 PM
walight01's Avatar
Default time for the valve adjustment
well after being gone for a month its time to get back to work on the bike i did my measurments on the valves today and heres what i got. also my feeler gauge set went in increments of .225mm so the low number i post is the last gauge that would fit and the higher number is the gauge that wouldn't
ex .20/.23 .25/.28 .25/.28 .23/.25 .23/.25 .23/.25 .25/.28 .18/.20
in .20/.23 .20/.23 .20/.23 .18/.20 .15/.18 .15/.18 .13/.15 .18/.20
usuable range is ex .22-.31 in .17-.25
i assume i want to put those numbers right in the middle of the range. i haven't pulled the cams yet to check the shim size. ill do that in the next day or so so i can order the shims while i'm gone.
Old Dec 25, 2006 | 01:48 AM
Default RE: time for the valve adjustment
I am trying to rationilize your post. I still do not comprehend what you are giving us.
Old Dec 25, 2006 | 02:02 AM
Notstock's Avatar
He is posting the measurements he got from checking his valves. He needs 3 shims onthe intake and 1on the exhaust according to what he wrote.
BR helped me with mine and it was a bitch for a first timer. I think he has considerable more skill than me though so should be a walk in the part for him.
Old Dec 25, 2006 | 03:05 AM
hmm ok, starting to see the message I think. Cyl 1 ex being .20and .25?
Old Dec 25, 2006 | 05:57 AM
walight01's Avatar
yeah what i posted was the measurments i got.the reasons for the 2 numbers per valve is b/c of my feeler gauges. so the first exhaust valve is somewhere between .2 and .23
Old Dec 25, 2006 | 07:55 AM
hmm, better get some better feeler gauges bro. Some dangerous territory with some iffy's.
Old Jan 2, 2007 | 05:15 AM
dogdragon's Avatar
while your there Dragone, get yourself a micrometer to size your shims.
Walight, your right about aiming for the middle size. Your manual should let you know if the old shims are usable or not.
Si
www.dogdragons.com
P.S. if your top end isn't rattling (I use a setherscope to listen to mine) there are probably ok and not in need of a change.
Tip. you can run old shims upside down for a short while to prolong there life, but not for long.
Old Jan 2, 2007 | 09:24 AM
Thanks dogdragon, I already have those tools.
yorgomiami
Ninja ZX-1100R
Oct 6, 2009 04:00 AM
markmeinteil
Ninja 250R
May 25, 2008 02:04 AM
Notstock
Jun 23, 2006 01:01 AM
ZX_9r
Jun 16, 2006 04:08 AM
lemac
Apr 22, 2006 07:05 AM
