throttle cable?
throttle cable?
i was trying to fix my sticking throttle but when i took it apart its not the throttle cable thats getting stuck. there is another cable, that i have no idea what it goes to which seems to be the problem.any idea what it is or how to fix it?
btw its a 91 600 ninja
RE: throttle cable?
ORIGINAL: crs24wilson
Now is a good time to invest in a good manual.
edit: because it just gets worse, good luck
RE: throttle cable?
They sell a do-dad that you clamp onto the cable so you can shoot some lube down it. Lube it, see if that doesn't help. Hoedogg is right you have two cables a "push", and a "pull". Lube both cables, and make sure the linkage isn't gummed up.
