Replacement battery
Old Jun 13, 2023 | 07:22 PM
Trailrider3428's Avatar
Default Replacement battery
My 2019 FI KLX250, even before I started with the mods was not an easy starter, particularly when temps dipped below 40 F. I have added the Marcelion Cam mod, lidless airbox, and EJK set up with Stage 1 mod settings, and lastly slipped on a Delkevic silencer.
It takes 4 stabs at the starter button to get this thing lit, and running. I have been using some fuel that has been sitting in a tank for quite a long period so I will be swapping to rec gas for the next fillup, that may be the issue, but I am also wondering if possibly an upgraded battery, something with more CCA might make a difference. I haven't been able to determine what the stock battery CCA rating would be, they seem to range from 90-140 CCAs. I really don't want to go to the Lithium batteries, but would prefer an AGM. What are your thoughts and recommendations?
Old Sep 24, 2023 | 07:35 PM
KevA's Avatar
Fuel is 100% going to hinder the starting see below.
  • Reduced Combustion Efficiency: Stale fuel may not burn as efficiently as fresh fuel. This can result in incomplete combustion, reduced power output, and rough starting and idling.
  • Hard Starting: Stale fuel may not vaporize as readily as fresh fuel, making it harder for the engine to start. This can lead to extended cranking times and potentially a failure to start the engine.
  • Clogged Fuel System: Over time, stale fuel can leave deposits in the fuel system, including the carburetor or fuel injectors. These deposits can restrict fuel flow and disrupt the air-fuel mixture, affecting starting and overall engine performance
    iirc the standard Battery FTX7L-BS is at best 90 CCA I would get yourself the equivalent at 140 CCA Sealed AGM
ahnh666
Mar 11, 2012 11:40 PM
PSUdude85
Jun 15, 2010 11:32 PM
clgdswr
May 17, 2009 07:09 PM
GC
Ninja 500R
Jul 24, 2008 07:07 AM
preemo_21
Jun 2, 2008 04:17 PM
