Rear brake replacement EX250J8R
Old Jun 2, 2010 | 11:26 PM
Crcaatalan's Avatar
Default Rear brake replacement EX250J8R
Aloha! I was slipping on some uneven gravel and gently set my bike down on its right and did some major damage. Im trying to buy a replacement part on the internet, but cant seem to figure out what part I need exactly based on the drawings. Can someone help? Also, I am pretty handy. But would I be able to replace it myself? It seems I will have difficulty with the bolts. Mahalo!!
Cheryl
Kawa EX250J8R
Attached Thumbnails Rear brake replacement EX250J8R-img00147-20100602-1221.jpg
Old Jun 3, 2010 | 01:12 AM
Welcome to KF
Stay, Step Holder P/N: 35063-0386-18R around $58
Easy repair to do. I would prefer using blue thread compound on all of the frame fasteners on a repair like this. Good luck and have fun.
Old Jun 3, 2010 | 03:13 AM
Prom's Avatar
Not much I can add to that. Hope you get her back on the road soon.
Welcome to KF!
Old Jun 3, 2010 | 03:25 AM
Crcaatalan's Avatar
Thank you so much! Your responses are awesome! What would I use to remove the bolts?
Old Jun 3, 2010 | 03:34 AM
Your basic metric open end wrenches probably to loosen and to adjust your break lever tension. Your mm allen wrenches. (do not use the ball end type since the bolts are so soft, the ball end does not provide a good enough working surface and it will strip the bolt heads)
edit: you are welcome, that is what motorcycling is all about.
Zeno
Feb 17, 2015 08:44 PM
brazeagle
Ninja ZX-14
Jun 21, 2013 03:39 AM
kronus
Jun 27, 2008 01:27 AM
dillon
Ninja 250R
Jun 4, 2008 07:10 PM
ntloser
Oct 23, 2006 02:07 PM
