pushrod seal problem!!
Old Jan 15, 2007 | 03:42 AM
andrer's Avatar
Default pushrod seal problem!!
Took the engine side cover to replace the clutch pushrod seal and a small piece fell on the floor. Problem is I have no clue where this piece goes. It's about 3/8 X3/8 square shapped with rounded off edges and 3/8 long. Also had a hole in the middle same size as the pushrod. Does this go at the end of the engin case where the pushrod fit to offer some support??? Please help. Thanks
Old Jan 15, 2007 | 06:58 AM
Default RE: pushrod seal problem!!
Find a fiche of your ride (what is it by the way?) Good luck.
Old Jan 15, 2007 | 03:07 PM
59allann's Avatar
Hi,
Go to this site and click onto parts search then select your make and model you will then be able to see an exploded diagram and hopefully will be able to locate the part and where it fits.
Hope this helps you 59allann.
Old Jan 15, 2007 | 03:09 PM
59allann's Avatar
Forgot to put the web address on last message
http://www.flatoutmotorcycles.com/fiche_section_detail.asp
Old Jan 16, 2007 | 12:33 AM
andrer's Avatar
Hey guys,
I have looked at several microfiche already and am unable to find it. It really baffles me as to what it is and where it's suppose to go.
Old Jan 16, 2007 | 01:01 AM
andrer's Avatar
Here are some pics of the mysterious parts
Old Jan 16, 2007 | 01:56 AM
Can you include yr, model and cc's of your ride? Or did I miss that little bit of info needed?
Old Jan 16, 2007 | 03:20 AM
andrer's Avatar
91 zx7
I did however just find the piece on a microfiche thanks to someones help. Seems like it's a internal bushing in the tranny. Now I'm trying to figure out if I'm going to have to take the tranny appart.
Old Jan 16, 2007 | 06:03 AM
congrats on your find.
russ90602
Sep 30, 2006 05:19 AM
emery
Aug 15, 2006 04:55 AM
jayden
Jan 22, 2006 09:14 AM
okie
Apr 10, 2005 11:32 AM
