pushrod seal problem!!
Took the engine side cover to replace the clutch pushrod seal and a small piece fell on the floor. Problem is I have no clue where this piece goes. It's about 3/8 X3/8 square shapped with rounded off edges and 3/8 long. Also had a hole in the middle same size as the pushrod. Does this go at the end of the engin case where the pushrod fit to offer some support??? Please help. Thanks
Hi,
Go to this site and click onto parts search then select your make and model you will then be able to see an exploded diagram and hopefully will be able to locate the part and where it fits.
Hope this helps you 59allann.
Forgot to put the web address on last message
http://www.flatoutmotorcycles.com/fiche_section_detail.asp
91 zx7
I did however just find the piece on a microfiche thanks to someones help. Seems like it's a internal bushing in the tranny. Now I'm trying to figure out if I'm going to have to take the tranny appart.
brewer882
Mar 15, 2014 01:26 PM
