Is it possible to repair petcock 88 Vulcan 1500?
Old 11-10-2007, 06:15 PM
car5car's Avatar
Default Is it possible to repair petcock 88 Vulcan 1500?
Is there cheap aftermarket one?
Old 11-10-2007, 07:25 PM
jeffzx9's Avatar
Default RE: Is it possible to repair petcock 88 Vulcan 1500?
If you're looking to go on the cheap, check out e-bay or maybe a "dedicated" vulcan website. Maybe do a Google for it. If not, see if you can get the old one apart. Keep us posted.
Old 11-10-2007, 09:55 PM
davehayward1's Avatar
Try "Bike Bandit", "Bear Tooth Kawasaki" or "Dennis Dirk". I believe they all stock aftermarket parts.
You can get a kit to rebuild it
I watched someone do this once. I am no mechanic but it looked like he replaced a small, postage-stamp size
rubber gasket and a couple of "O"rings to re-establish suction of the gas into the carb
He said the most important thing is to have the two surfaces that "sandwich" this gasket as flat as possible
so that no air can enter or escape
He used a file to do this
Hope this helps
Like I say - I am no mechanic
Dveve
Old 11-15-2007, 03:59 AM
speedracer138's Avatar
The parts may be available thru special order fronm the dealer. Maybe another model or year will work also.
Old 11-15-2007, 10:18 AM
yoman1's Avatar
I like http://www.bikebandit.com/thet have oem and aftermarket.
bear0009
07-28-2006 09:37 PM
bear0009
07-28-2006 09:37 PM
riderk9
06-08-2006 08:22 AM
kawasakivulcan1500
12-01-2005 10:06 AM
jsage
09-20-2005 01:08 AM
Quick Reply: Is it possible to repair petcock 88 Vulcan 1500?
