Need help with Fuel Line problem
Old 12-25-2006, 06:46 AM
Philip's Avatar
Default Need help with Fuel Line problem
I just took the two hoses off the fuel valve on my KZ650 and thought both were fuel lines. So, I poured carb cleaner into both tubes. Now, I think "that was dumb." I think one was a vacum line. Have I got a problem and can I fix it?
Thanks for any real help.
Old 12-25-2006, 07:42 AM
shinobi636's Avatar
Default RE: Need help with Fuel Line problem
Is the vacuum line dried out, or cracked? if not then it should be fine. If it is then vacuum line is like 25 cents a foot. Fuel hose is generally made from solvent resistant hose, so it should be OK. I would go cut some extra line from one of the vac lines on my Jeep, and use that.
Old 12-25-2006, 08:00 AM
Welcome philip to KF.
The vacuum line clear now?
Old 01-02-2007, 04:01 AM
dogdragon's Avatar
If the engine is running well, then you don't have a problem.
Si
(www.dogdragons.com ...my bike web site)
86chev6bt
07-21-2010 07:53 PM
gihess
Classic Sportbikes
04-19-2009 05:44 PM
Kawacon
08-22-2007 12:07 AM
SYK35
04-08-2007 04:11 PM
ktn
03-06-2007 04:12 AM
Quick Reply: Need help with Fuel Line problem
