Fuel line kink
Fuel line kink
I created a problem when I added an in-line fuel filter. The hose has a serious kink in it which shuts off fuel flow. I have searched for a 5/16" 90 degree elbow with barbs on both ends (for 5/16" hose to slip over), and I can only find tees.
The only other alternative I can think of, is to insert a loosely coiled spring inside of the hose in the area of the kink.
Do you know a source for 5/16" 90 degree barbed elbows?
Any other ideas?
Any other ideas?
RE: Fuel line kink
Close, very close. At the bottom of the same page, I see one made of Acetal, which will work with gasoline. It is metric, but the 8mm is only 0.003" larger than 5/16". It will work fine.
Thank you, thank you.[sm=smiley20.gif]
RE: Fuel line kink
Or, you can make your fuel line longer and coil the extra tubing, versus making a sharp bend. Zip tie the extra to the frame or other secure spot. Kinda cobbed, but it would work and save you buying teflon tape and pipe fittings...
