Fuel line kink
Old 08-18-2007, 02:24 AM
Kawacon's Avatar
Default Fuel line kink
I created a problem when I added an in-line fuel filter. The hose has a serious kink in it which shuts off fuel flow. I have searched for a 5/16" 90 degree elbow with barbs on both ends (for 5/16" hose to slip over), and I can only find tees.
The only other alternative I can think of, is to insert a loosely coiled spring inside of the hose in the area of the kink.
Do you know a source for 5/16" 90 degree barbed elbows?
Any other ideas?
Old 08-18-2007, 01:24 PM
Default RE: Fuel line kink
McMaster-Carr Part# 53055K262
Old 08-18-2007, 03:43 PM
Kawacon's Avatar
Close, very close. At the bottom of the same page, I see one made of Acetal, which will work with gasoline. It is metric, but the 8mm is only 0.003" larger than 5/16". It will work fine.
Thank you, thank you.[sm=smiley20.gif]
Old 08-18-2007, 04:04 PM
oops, you are correct. Part # 2429K48
I read chemical resistance and did not read further.
Old 08-21-2007, 12:08 PM
jeffzx9's Avatar
Or, you can make your fuel line longer and coil the extra tubing, versus making a sharp bend. Zip tie the extra to the frame or other secure spot. Kinda cobbed, but it would work and save you buying teflon tape and pipe fittings...
Old 08-22-2007, 12:07 AM
No Teflon tape required Jeff. But that is a good idea as well.
IamJames
07-04-2009 04:46 PM
gihess
Classic Sportbikes
04-19-2009 05:44 PM
SYK35
04-08-2007 04:11 PM
ktn
03-06-2007 04:12 AM
Philip
01-02-2007 04:01 AM
Quick Reply: Fuel line kink
