Need help with Fuel Line problem
Old Dec 25, 2006 | 06:46 AM
Philip's Avatar
Default Need help with Fuel Line problem
I just took the two hoses off the fuel valve on my KZ650 and thought both were fuel lines. So, I poured carb cleaner into both tubes. Now, I think "that was dumb." I think one was a vacum line. Have I got a problem and can I fix it?
Thanks for any real help.
Old Dec 25, 2006 | 07:42 AM
shinobi636's Avatar
Default RE: Need help with Fuel Line problem
Is the vacuum line dried out, or cracked? if not then it should be fine. If it is then vacuum line is like 25 cents a foot. Fuel hose is generally made from solvent resistant hose, so it should be OK. I would go cut some extra line from one of the vac lines on my Jeep, and use that.
Old Dec 25, 2006 | 08:00 AM
Welcome philip to KF.
The vacuum line clear now?
Old Jan 2, 2007 | 04:01 AM
dogdragon's Avatar
If the engine is running well, then you don't have a problem.
Si
(www.dogdragons.com ...my bike web site)
86chev6bt
Jul 21, 2010 07:53 PM
gihess
Classic Sportbikes
Apr 19, 2009 05:44 PM
Kawacon
Aug 22, 2007 12:07 AM
SYK35
Apr 8, 2007 04:11 PM
ktn
Mar 6, 2007 04:12 AM
