need help
Old May 11, 2011 | 05:03 PM
jeffzl1000's Avatar
Question need help
hi, im new here and need some help/advise. i own a zl1000 and have a strange problem. my ride will start fine and idle fine but at about 3k rpm it start to bog out if i work the rpm up past about 4 or 5k it goes away. the same symptoms happen when i drive it. when im cruising or giving steady throttle at about 3k rpm it bogs in and out and the tach goes up and down to zero. if i work the throttle and speed up over 5k it will smooth out and run. ive taken the carbs off and cleaned them good and it did not correct the problem. has anyone been through this before?? thanks.
Old May 13, 2011 | 02:14 PM
Check the carb synch after you are sure that all other carb related checks are completed. ie carbs are clamped and positioned properly, float heights are set. Good luck and welcome to KF
joshmoe
May 13, 2014 02:24 AM
Badmankatink
Jun 11, 2009 02:06 AM
mikess06
ZZR 600
May 14, 2008 03:16 PM
MK1gti20v
Aug 12, 2005 04:49 PM
