MY SAD BIKE
Old Sep 17, 2007 | 05:33 AM
Default RE: MY SAD BIKE won't start when it's hot
hahaha, if I bat my eyelashes, they would prolly charge me 3x more!
Old Sep 17, 2007 | 06:50 AM
markmeinteil's Avatar
lol
Old Sep 17, 2007 | 07:00 AM
ORIGINAL: pat
Once the bike heats up, it revs up and down for a few seconds then just turns off. It won’t fire up at all no matter how many times I try to restart it, even though the motor is trying to turn over it sounds like it is starving of something. The only way it starts again is when I leave the bike cool down. Then it starts up as if it’s a innocent little angel, until it warms up, could fuel cause that? Do you think it needs fuel to be 100 percent once it reaches a certain tempters? The sad part about it is I LOVE my bike Pat
[sm=grinangel.gif]< that's my bike
By telling me that, it says to me this is a non-ignition related issue. Like others have said, it's an air/fuel delivery problem of some sort. I believe as it revs up, the engine is probably leaning out big time. (not getting enough fuel.) Unless you happen to be mechanically inclined, or buy a repair manual to teach yourself, you'd better just take it into a shop.
Old Sep 17, 2007 | 08:20 PM
jeffzx9's Avatar
Pat, I agree with shinobi and mark on the fuel issue. It sounds like it just plain runs out of juice.
One of the benefits of owning a bike is that you learn about simple (most of the time) mechanical issues that affect how your bike runs. Many of the problems are a "follow the clues" sort of thing. In your case, I'd begin by following the fuel line. You can do this. It may be something as simple as a clogged fuel filter, or gunk in your petcock (fuel cutoff lever on the bottom of your fuel tank.)
Take the fuel filter off and clean it out. Usea cleaning solution (kerosene, solvent, spray carb cleaner, etc. You can buy a can at Wal-Mart) and a toothbrush. See if there is any obvious gunk. Reassemble. Try your bike again.
If that didn't work,remove the fuel line coming out of the bottom of the fuel tank. Put a small catch can under the tank to catch the fuel, as you turn the petcock **** on/off/on/off. Make sure the gas flows as it should. I doubt if this is the problem, but it's worthtrying. You might even loosen the gas cap on your tank when you try this, just to see if there's a vacuum thatcauses your fuel line to stop flowing. Reassemble. Try your bike with the gas cap slightly loose.
There is SOMETHING causing your fuel to stop flowing as your bike warms-up.
Try these suggestions, and get back with us. We can walk you through the next procedures. We're here to help you as far as you want to pursue it by yourself. It's all patience and persistence;YOU CAN DO THIS. (Trust me; if we can, so can you.) Never pay someone else for your missed learning opportunity.
Good luck.
Old Sep 17, 2007 | 11:34 PM
Notstock's Avatar
ORIGINAL: Dragone#19
hahaha, pat. The thing is, if you are not willing to work on "your ride", then you will have to takein the arss. Your choice of course. Wish ya luck.
this is what you wanted to post.
Sorry Pat, sometimes they make it sooooooo easy and I have too!
If you do not have anyone you can trust where you are your best bet is to take it to a smaller shop rather then the stealership. Tell us what city you live in and someone may know or will be able to help you find a trustworth mechanic. There are some out there but not many
Old Sep 17, 2007 | 11:48 PM
pat's Avatar
pat
How sweet of you, Jeff zxp shinobi636,dragone19, markmeinteil,to help me out you are indeed all grouse people.
I am going to attempt do fix it myself. As I explained I’m only 50 kilos and 5 foot 2 so there is not much of me, and some of the bolts are hard to undo, but this week end I’m gonna eat some spinach and do what you suggested, why cos all you guys gives me the strength and guts to do it, I will make you all proud of me, I will let you know how I go.
Thank once again, words can not describe how much I appreciate all your time and help
Pat
Old Sep 18, 2007 | 05:14 AM
ORIGINAL: Notstock
oh, that is bad!
Old Sep 18, 2007 | 05:17 AM
pat,
grouse people.
I may have missed that dinner then. Good riding.
Old Sep 18, 2007 | 12:09 PM
jeffzx9's Avatar
I'm only a grouse in the morning before I have my coffee.
frrogger1
Apr 18, 2006 11:16 AM
Funkdock
Apr 5, 2006 06:26 AM
056r
Jan 23, 2006 09:10 AM
gotrice
Dec 5, 2005 09:02 PM
onewheel
Apr 4, 2005 08:34 AM
