My bike is SWALLOWING gas!!!
Old Jul 25, 2007 | 04:08 AM
alazee123's Avatar
Default RE: My bike is SWALLOWING gas!!!
idle seems to be a little choppy.... and it some times seems to get stuck after i let off the trottle at 3000 rpm... sometimes it stays there till i trottle it up again then it slowly drops.... dnt really have to much problem in any of the other gears...
Old Jul 25, 2007 | 04:09 AM
The hardest part on rides is the pain in the **** at times to remove them or install them. If you know about carbs and the different circuits in a carb, can actually clean thouroughly a carb, it is all the same.
Old Jul 25, 2007 | 09:26 PM
jeffzx9's Avatar
Likely your main jetsdoing their job. If you've put a full Muzzy on, and are running with very minimal baffle in the can, in order to have a proper air/fuel mixture, the mains are pretty big. When you really crank into the throttle, your mains flowalot of gas. I'm willing to bet if you stay out of the throttle;if you keep the tach below 8-9K, your gas "mileage" will improve.
Old Jul 25, 2007 | 11:25 PM
Notstock's Avatar
ORIGINAL: jeffzx9
yea if your riding around 10-12k your milage will suffer, but it is more fun up in the 10-12 range
Finger Mullet
Oct 21, 2008 02:03 AM
gerrynolan
Sep 7, 2008 01:25 PM
Finger Mullet
May 2, 2008 01:11 AM
MaverickAus
May 19, 2007 07:45 PM
cassa63
Aug 17, 2006 09:37 AM
