Let's talk Sprockets and Chains
Old Jul 4, 2007 | 12:16 AM
markmeinteil's Avatar
Default Let's talk Sprockets and Chains
I've got my rear wheel off the KZ750to change out the tire, and figured while I have it apart I would maybe put a larger rear sprocket on. I want to knowif you would likely have to get a longer chain whengoing from the original 32 tooth sprocket to a 36 or 40 tooth.
Old Jul 4, 2007 | 01:05 AM
walight01's Avatar
Default RE: Let's talk Sprockets and Chains
if your going to change sprockets i would change the chain anyways. if there is any wear on the chain it will ruin the new sprockets very quickly. as far as needing a longer chain, maybe the 36 won't but the 40 probably will. i would order a chain/sprocketscombo. replacing both front and back. and then you can either cut the chain to length or it willl come precut to the sprockets you order.
Old Jul 4, 2007 | 01:24 AM
Thanks for the advice.
My old chain and rear sprocket don't really showmuch wear. But, I don't know how much adjustment I would have leftafterjumpingup 8 teeth.It's probably for the best to replace it all. I wasn't able to find any chain/sprocket kits for my bike though. It must be too old.[:'(]
Old Jul 4, 2007 | 01:31 AM
Oh I thought this was about real sprockets on real bikes.[8D][8D][8D] Now you know I'm just messing with ya right?
The Mekon
Sep 10, 2009 04:21 AM
Marty
Feb 13, 2008 04:46 PM
rocketman
Oct 28, 2007 07:59 PM
deej
Mar 29, 2007 12:28 AM
Scrtsvc
Nov 30, 2005 05:34 AM
