kx85 bogs on top
Old Jun 13, 2012 | 01:21 PM
ruxpin22's Avatar
Default kx 85 bogs
thank you I will try the reeds tonight I believe vforce reeds are able to be flipped will see as they clip in and are held with a slider at the bottom no screws.
But I do remember one as bieng a little too easy moving will let ya know tonight if it works , more left in the wallet sounds better to try first.
Old Jul 29, 2012 | 04:12 AM
jake's Avatar
Default Did you find the problem
Hey, I was just curious if you got your kx85 going. Where did you start and end up? I hope the couple posts helped you. Ussually when I resort to blogs to troubleshoot I get too many random inputs that just dont add up. Let us know how things are going for you.
Old Jul 31, 2012 | 10:18 PM
ruxpin22's Avatar
Default kx85 bogs
Hey Jake
Thank You To all who gave input. with so many different things to check for possible solutions I actually checked but didnt realize til checked again but it was the reeds that were the problem had one floppy one in the middle so flipped it and changed its position til I get new ones have gd low end and good high end power but not as gd in the middle but will be gd for us til replaced.
Again thank you to all who gave input it also helped with dialing in other stuff that was not the best as well.
Ted
Old Apr 10, 2013 | 12:00 AM
kawasaki489's Avatar
Im having the same problem with my 05 kawasaki kx 85 i replaced the reeds the carb brand new motor except exhust valve re jetted 10 times only does it at top end wide open tried with choke on didnt matter still did it.New coil cdi new stator everything new!!!!!!no body knows really frustrting seems like it hits a rev limiter every time only with a load on it sitting still reving it up no problem......What plug are you running?????
Old Oct 22, 2014 | 01:33 PM
Cjsdad731's Avatar
Same exact problem as me bud wish the thread had a solution.new to the site will keep trying
Old Oct 22, 2014 | 01:39 PM
Cjsdad731's Avatar
The bike is a 2014 kx85 runs great on low and mid rpm when you hit the top it's like it hits a rev limiter we have two bike so I changed the Cdi ,stator, cleaned the carb several times reeds look ok ordered new ones anyway and waiting for new top end jetting is spot on it just did this while riding the track last weekend about an hour into riding also repacking silencer I'll inform how things work out
jredding
May 17, 2009 01:34 PM
OGmackPLRcool
May 6, 2009 11:24 PM
elektryc750
Jun 19, 2008 10:29 PM
macfast12002
Aug 13, 2007 07:14 AM
americasboogyman
Feb 3, 2007 09:20 AM
