KX250 won't run!
I rebuilt the top end on my 99' KX250. It starts but only runs at hig RPM with the choke on. Once the chock is off it will not run or idle. You have to keep the throttle active to keep it running. Sounds like carb to me. Any input would be appreciated.
Do all the basic carb cleaning stuff, check needle position. Maybe a cracked reed or a simple as the rubber boot being ripped between the reed cage an carb. With a boysen cage it's real tight and usually tear after awhile.
