Kx 100 rear shock not working right, Help!
I just bought a 2007 kx100 and it worked great. I wanted to change the compression damper and rebound damper back standard. I followed exactly what it said to do by rotating it clockwiseto fully seated hight then go back eleven clicks. I also changed the compression to 3 just by rotating at back. After i sat on it its really messed up. Barely has any rebound and doesnt really seem to have as much travel when i sit on it. i changed it to the highest and lowest setting and still no difference. Any ideas on what i might have done or how i can fix it?
Welcome To Kawasaki Forums.
Turn On Some Tunes And Enjoy The Ride.
They're a lot of Good Members Here and they will do there Best to Help You out with Your Questions. Sometimes It Takes A Little Longer Then Others. So, hang-in there.
