Kx 100 rear shock not working, Help!
I just bought a 2007 kx100 and it worked great. I wanted to change the compression damper and rebound damper back standard. I followed exactly what it said to do by rotating it clockwiseto fully seated hight then go back eleven clicks. I also changed the compression to 3 just by rotating at back. After i sat on it its really messed up. Barely has any rebound and doesnt really seem to have as much travel when i sit on it. i changed it to the highest and lowest setting and still no difference. Any ideas on what i might have done or how i can fix it?
100, adjust, adjustment, changing, clicks, compression, kx, kx100, move, rear, rebound, shock, suspension, wont, working
