Ignition Issues
Old Aug 16, 2009 | 10:08 PM
AfghanVet's Avatar
Default Ignition Issues
I have a 1982 KZ440 LTD
I went to start my bike last night after the first time I actually used the handlebar lock on it. And nothing, turned the key, no lights came on and pressed the button and obviously the starter wouldn't turn over. I thought it might be a dead battery but tested it and attempted to jump it and still no dice. I also looked around for loose or broken wires and didn't find any. Is there something inside the ignition area like a kill switch that prevents the bike from even turning on the electrical system that might be stuck after using the handlebar locks?
Old Aug 17, 2009 | 02:36 AM
Have you checked the fuses? Is the bike in neutral and the kill switch turned to on?
Old Aug 17, 2009 | 12:14 PM
AfghanVet's Avatar
Kill switch on the handlebars is turned on, and I'm not entirely sure where the fuse box is. This is my first bike.
Old Aug 17, 2009 | 07:19 PM
AfghanVet's Avatar
Found a loose connection I hadn't seen before, I got it working. Thanks Dragone you led me in the right direction it was near the fuse box.
Old Aug 18, 2009 | 12:47 AM
awesome. Congrats on the fix.
Old Aug 18, 2009 | 12:58 AM
95451's Avatar
And another one! way to go Dragone
Old Aug 18, 2009 | 01:19 AM
hahaha, just throwing ideas out there to help my brothas out.
Old Aug 18, 2009 | 10:30 AM
AfghanVet's Avatar
Thought I had it fixed, then it died on me again, figured out that what I thought was a loose connection was NOT the problem, went back and screwed around and found a bad connection on the other side of the bike, cut out that connection and installed new connectors and NOW the bike is running fine, lol.
Old Aug 19, 2009 | 06:25 AM
hahaha, congrats on the fix again!
Old Aug 19, 2009 | 12:13 PM
jeffzx9's Avatar
Ahhh, (forum) membership has its privileges.
Good call, Drag.
uncaged
Jun 19, 2012 02:19 AM
jhoffy22
Jul 25, 2011 05:15 AM
acerulz
Mar 28, 2006 03:56 AM
Jutboy
Mar 1, 2006 08:30 AM
incabiker
Feb 28, 2006 02:37 AM
