i need sugestions whats wrong
Old Mar 1, 2008 | 08:09 PM
andsome1422's Avatar
Default i need sugestions whats wrong
i have a 1995kawasaki zx7r and it will start and run for about 10 minutes then start idoling weak and low and then eventually just die. if i try to start it right after that it might start for like 30 sec then do the same thing and eventually it wont start unless u let it sit for a little while. if u let it sit for like 10 minutes it might run for 1 then do the same thing.
Old Mar 1, 2008 | 08:53 PM
jeffzx9's Avatar
Default RE: i need sugestions whats wrong
Sounds like bad gas. How long since you put fresh in? What kind of weather do you have? Give us more details about the circumstances.
Old Mar 1, 2008 | 10:35 PM
Possibilities: Bad gas, restricted metering of the fuel (ie carb cleaning is needed), wrong float height.
Old Mar 2, 2008 | 09:03 PM
speedracer138's Avatar
I agree. Could also be a clogged or restricted fuel filter of fuel valve (petcock). If it has a fuel pump, the pump may have gone bad.
vlad
Ninja 500R
Nov 6, 2009 02:07 AM
09'Kawi250s
Jun 5, 2009 04:21 PM
TUCAZ520
Apr 8, 2009 04:19 AM
ryninger
Jul 30, 2005 12:15 PM
