I have a carb issue
Old Aug 19, 2013 | 02:37 PM
emljr's Avatar
Default I have a carb issue
05 klx 300 is the bike. Gas started to spew from the float bowl drain screw while out on the trail. First just thought maybe the screw loose. But screw was tight, bottomed out actually. Fuel still leaked. Tied a not in the hose but fuel ran out the overflow-- float not working right(?). So get back home and take carb out and apart. Cleaned jets ports, etc. while examining the float bowl noticed that air passed through the drain with screw in place, bought new screw but still passing air. Mechanic said there is a flat spot inside the screw hole. So I guess the float bowl shot, but no replacement through dealers. Now what?
Old Aug 19, 2013 | 04:07 PM
jeffzx9's Avatar
If all else fails, I'd probably try some petroleum-resistant Permatex "gasket maker" on the screw threads. Might booger-up when you actually need to drain the bowl...but how often is that? I suppose the longer-term solution would be to drill, tap, use a very slightly larger drain screw.
Old Aug 19, 2013 | 06:11 PM
emljr's Avatar
This is why I come here! Outside the box thinking. I'll try the gasket maker and also look for a larger screw etc just n case. Thanks Jeff
trj2433
Oct 23, 2011 06:23 PM
BleedingGreen
KDX200
Aug 21, 2009 03:33 AM
leichenauer
Jul 5, 2009 11:45 PM
dngrrngr
Mar 14, 2009 06:53 PM
