How much oil does my 95 zx7 hold?- help
Old Aug 16, 2006 | 06:37 AM
Jmanf150's Avatar
Default How much oil does my 95 zx7 hold?- help
I put about 4 quartz in it but still cannot see it .. why is this ?
Old Aug 16, 2006 | 07:39 AM
BigRig18Wheeler's Avatar
Default RE: How much oil does my 95 zx7 hold?- help
Welcome to the forums....
That bike should hold around 3 qrts or so if I remember right. Are you checking the sight glass with the bike upright and level? Maybe the oil is so clean you are just not seeing it. Try making your own homemade dipstick maybe....If you are still unsure.
Old Aug 16, 2006 | 08:18 AM
evil636's Avatar
Knee Dragging Pimp
i think a zx7 was around 4 courts, i cant remember off hand but the bike needs to be straight up in order to see it in the sight glass. even if its on the side stand the oil will not show in the glass.
Old Aug 16, 2006 | 08:53 AM
markmeinteil's Avatar
did you put the drain plug back in? LOL
Old Aug 16, 2006 | 03:01 PM
Jmanf150's Avatar
yeay no leaks or anything just cant see the oil, the bike is almost upright and you would think you could see a little bit of oil- i guess i am going to try to put more in their at this point i am ready to ride- thanks for the help
Old Aug 17, 2006 | 07:00 AM
evil636's Avatar
Knee Dragging Pimp
i wouldnt stick more oil in there then its intended to hold man, your asking for trouble.
Old Aug 17, 2006 | 07:59 AM
ORIGINAL: Jmanf150
The "Almost upright" has me abit concerned. 4qts is usually the norm in oil. You may not be seeing the level especially if you are running synthetic. So check the level when the ride is fully upright.
Old Aug 18, 2006 | 01:58 AM
walight01's Avatar
my 7 takes around 3.6 l which i believe is like 3.8qt the bike much be staight up and down and on flat ground for you to get a accurate reading. if its on its side stand, you won't be able to see the oil at all.
isaacpinnacles
May 31, 2009 09:52 PM
RDHJ
May 24, 2009 04:18 AM
illenium
Aug 31, 2008 12:28 AM
camo2000zx7r
Feb 3, 2008 10:44 PM
kawicole
KX125
Jan 9, 2008 02:14 AM
