How much?
Old Nov 20, 2007 | 10:42 PM
scottay321go's Avatar
Default How much?
Time for a clutch! How much should I expect to pay the stealership for a new clutch and install? Also, I think I may need my carbs cleaned and/or re-jetted....is this expensive? Thanks for the help fellas!.....and girls, hehe.
Old Nov 20, 2007 | 10:47 PM
Compstall's Avatar
Default RE: How much?
I'll do it for the beer n' conversation.
Old Nov 20, 2007 | 11:11 PM
SOLD!!!
Old Nov 21, 2007 | 12:13 AM
davehayward1's Avatar
For my 81 KZ 750 LTD (4 cylinders/4 carbs) a cleaning/rejetting ran $400
The clutch I might try to do myself with a Clymer manual
(and -- I am not a tool guy)
Good luck with both jobs
Old Nov 21, 2007 | 03:36 AM
Deuce's Avatar
I'm gonna say that carbs is likely easier than clutch if you plan on doing it yourself. I've done carbs. Easy peasy, bacon greasy. Clutch... I'd be more careful... Way more.
Old Nov 21, 2007 | 04:33 AM
I'd prolly leave my self a 3 hr window. Fairings, oil, clutch, adjustments, etc. Not including the pad soak in.
Old Nov 21, 2007 | 06:59 AM
dilysi's Avatar
or call your dealer and ask for a quot
Old Nov 21, 2007 | 09:48 PM
Prom's Avatar
Agreed, call the dealer, ask for a number then add 50%, or have someone smarter than you show ya how to do it (you will be required to provide at minimum lunch or beer so negotiate beforehand)
Old Nov 22, 2007 | 03:51 AM
jeffzx9's Avatar
Do it yourself, unless you have a slipper clutch. Make a note of how the clutch discs come out. Let the new ones soak for about an hour. Re-stack 'em and put em back in. Clean the surfaces of the gasket area with a clean rag with acetone or alcohol, and make sure there's NO oil residue on the mating surfaces. Use Permatex on both sides of the gasket, re-mate, snug the bolts (don't squeeze out all the goo!!), let sit for a day, refill with oil to spec, and you're good to go.
Carbs? Pretty much the same deal. I agree with Deuce; easy.
Don't pay some dealer to mess up your bike.
My 2 cents. Save your money for the best parts you can buy.
pboi
Sep 19, 2009 02:31 AM
illenium
Aug 31, 2008 12:28 AM
DANASAKI
Jul 5, 2008 05:36 PM
camo2000zx7r
Feb 3, 2008 10:44 PM
kaw98zx6r
Aug 14, 2005 03:37 AM
