ZZR 600 Electrical
Old Nov 23, 2007 | 02:50 AM
ZEROZERO's Avatar
Default ZZR 600 Electrical
hi i just bought a 2005 ZZR 600 off a friend of mine he sold it to me cheap becuase the bike had a problem with its alturnator because he would charge the battery and then when the battery dies the bike dies so i still dont know if it is the alturnator or just something else causei took the cover off today and it look fine. so does anybody have an input about this and is there anyone selling the part i need to fix this i i greatly apreciate the help thanks guys.
Old Nov 23, 2007 | 03:03 AM
zzrick's Avatar
Default RE: ZZR 600 Electrical
I don't know, although I have the same bike I have not had the same problem. I had a problem of the bike cutting out but it was just the cables were loose.
Old Nov 23, 2007 | 03:20 AM
Put your meter on the battery. Record the voltage. Then record the voltage when the ride is started and running at say 2000 rpm. Does the voltage increase any?
Old Nov 23, 2007 | 03:22 AM
ZEROZERO's Avatar
well the battery is just there to start the bike right? so when the bike runs it just powers of the alturnator like a car
Old Nov 23, 2007 | 03:24 AM
ZEROZERO's Avatar
ORIGINAL: Dragone#19
well the batty is just there to start up the bike right? then when the bike i started it runs off the alturnator so i would be able to disconnect the batter like a car
Old Nov 23, 2007 | 03:28 AM
Yes, if the frame ground is good. I have not done that though. I am lazy, I use a meter. lol
edit: 4000 rpm is needed for testing my alternator output voltage. ('06 10r)
Old Nov 23, 2007 | 04:05 AM
ZEROZERO's Avatar
Ok so where is the frame ground located ill clean it or what ever and do you know where i can fine like a free online service mannual thanks you have been great help
Old Nov 23, 2007 | 04:10 AM
I only have the D and E models in pdf. Sending emails in the past on manuals have not been successful lately. pm me your email and I will try if interested.
Old Nov 23, 2007 | 04:35 AM
jeffzx9's Avatar
If your alternator is bad, your bike won't continue to keep going. I had an old GXXR and when the alternator went, so, too, did the bike; stopped dead in its tracks.
Drag has good advice. Check the volatge with a meter. You might also just get a battery to eliminate the variable; not a bad thing to do if you just bought the bike, so you know it's fresh. Then, if you still have the problem, (and the lights get dim, dimmer, dead) you know its the alternator.
snowwy66
Nov 18, 2007 01:34 PM
kotacam
Oct 2, 2005 08:56 PM
poolhustler21
Sep 27, 2005 12:48 AM
Gerg
ZZR 600
Jul 9, 2005 12:49 AM
Gerg
Jun 18, 2005 01:07 AM
